Diesel fuel additives/conditioner
Old Dec 17, 2012 | 10:23 AM
p38251's Avatar
p38251
Default Diesel fuel additives/conditioner
I tried doing a thread search. Couldn't get anything to come up. What are you guys using if anything. Fuel Additives/Conditioner. My old truck was a gasser, and I ran Star-Tron. Thanks
Old Dec 17, 2012 | 12:40 PM
Jigabop's Avatar
Jigabop
posted in your other thread, but here it is again.
I run ashless 2-stroke oil from wally world. but that will damage your emissions controls on the 6.7, so either soypower biodiesel, or opti-lube is the best bet for you.
the chart shows the lubricity of the fuel after the additive. lubricity in the fuel is good for the injectors, lift pump, and injection pump.
helps keep injectors from sticking, and reduces injection pump and lift pump wear.
btw chart above was a professional study done by a diesel performance shop. it is completely unbiased as they were simply trying to find out what works and what does not.
this chart shows bosch (oem injection pump manufacturer for all cummins generations injection pumps and injectors) test results for pump wear based on fuel lubrication
Old Dec 17, 2012 | 07:44 PM
p38251's Avatar
p38251
Thank you for the info. I was reading a little about diesel kleen today. HFRR score, is that how much lubricating properties each one has?
Old Dec 17, 2012 | 09:38 PM
Jigabop's Avatar
Jigabop
HFRR is the lubricity yes..lower number = more lubrication higher number = less lubrication
Old Dec 19, 2012 | 05:41 PM
cumminsrebel's Avatar
cumminsrebel
Do u add the 2stroke oil every fill up or how often?
Old Dec 19, 2012 | 06:18 PM
p38251's Avatar
p38251
I spoke with a Tech yesterday, they say that additives/conditioners will harm the DPF. And if they can prove it no warranty.
Old Dec 20, 2012 | 11:37 AM
Jigabop's Avatar
Jigabop
Every fill up unless I fill with B5 biodiesel.
128:1 mix or 1oz per gallon.
I buy it by the gallon at walmart for $12/gal a gallon will get me through 4 32 gallon fill-ups.
optilube will not harm the DPF.
just don't tell them you run it and they can't prove it
Old Dec 20, 2012 | 11:42 AM
cumminsrebel
Thanks for the info
Old Dec 20, 2012 | 11:57 AM
Jigabop's Avatar
Jigabop
no prob.
between the 2-cycle oil diet, and a good lift pump, I have had zero fuel system problems. injection pump is happy and healthy even with me pushing over 500hp out of it. never misses a beat.
lubrication used to not be a problem, but they changed our fuel back in 2007 which caused the lubrication problem. ultra low sulfur diesel has been stripped of its lubricity. while it may be good in the newer diesels, its harsh on the older diesels that were not designed for it.
Old Dec 20, 2012 | 01:35 PM
p38251's Avatar
p38251
Thanks for the help. I can run Bio 5% I think. So alittle in each tank would help a well.
