So i need like an air dog or fass system to fix that or what you recommend has 75hp injectors,120 juice w/ attitude,4in pipe turbo back w/ 8in stack, s&b intake
u need to the correct system for your engine, 33 psi is getting dangerous, 45 psi will blow the seal out of the front of the injection pump and/or ruin the pump, and fill the crank case with fuel,
you need something to either regulate your fuel pressure down to the specified range, or something like a fass system with a draw straw V since you said you have the in-tank pump.
