1998 Cumming 5.9 24 v Ram2500 no fuel
Old Dec 21, 2012 | 07:01 PM
Fyr1's Avatar
Fyr1
Unhappy 1998 Cumming 5.9 24 v Ram2500 no fuel
My 98 Ram 2500 dropped dead cranked fine could not restart had it towed home.Plugged in Scanner and found it was unable to connect. Checked DLC
good pin 4 ground and good battery pin 16 no pin 5 sensor ground.Checked the sensor ground plug that plugs into the engine cumputer unit pin 4 on the 50 pin connector and it was open I continued the all data check Test NS-6A measured the resistance between SCI ( Serial communication interface )transmit and Receive circuit. No resistance in between the 2 it was suppose to have a resistance of less than 5.0 ohms .Voltage with key turned onto lift pump goes to 9.6 and drops to 7.6. I checked the pump with 12 v direct and it worked fine.
Something or someone is sucking down the voltage.checked fuses and relays.
Perhaps too much resistance somewhere I have 70 ohms at the starter relay where there is suppose to be resistance but have no idea of the resistance value. The Pcm passed all the all data tests. Help!!!!
Old Dec 22, 2012 | 01:23 PM
Jigabop's Avatar
Jigabop
whats your fuel pressure like, and any codes doing the key trick?
Old Dec 27, 2012 | 11:14 AM
Fyr1's Avatar
Fyr1
Can you get codes out of a 1998 Ram 2500 using the key? How do you do it ?
Old Dec 27, 2012 | 11:26 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
I've found and read that the key dance trick doesn't work on 98's for some reason. Only 96-97, and 99-up.
Old Jan 7, 2013 | 01:56 PM
Jigabop's Avatar
Jigabop
on-off 3 times leaving it on the 3rd time without starting it. should display codes on the odometer
if you cant get codes that way, go to parts store and have them hook a scanner up to it to pull the codes from the obd-II port
Old Jan 8, 2013 | 09:48 AM
Fyr1's Avatar
Fyr1
I tried key trick it did not work my obd 2 port does not connect with my scanner. I found the sensor ground open .I dropped the truck off at Dodge hoping they could find where the open is. I tried and could not .I was only able to narrow it down to the sensor ground wire that came out of the PCM in the harness that mounts to bulkhead.Wire goes down to transmission without a lift it is difficult to get to.I am optimistic the dodge tech can repair it. I did get the truck running by changing the fuel pump which should have been replaced when the injection pump was.
