Superspring or air bags
Old Feb 7, 2013 | 12:09 PM
Kyle2012RAM's Avatar
Kyle2012RAM
Default Superspring or air bags
What do y'all think is better for a 2012 2500 RAM, putting a set of firestone air bags on it or putting on some supersprings? I don't pull a trailer all the time but when I do its a GN stock trailer with 15,000-28,000 lbs worth of cattle in it, or hauling bales 11-14 at 1100-1700 lbs each. Those would be the biggest loads I would pull. I pull them on dirty roads, fields and pastures so they aren't smooth trips, I take it easy but still rough. Thanks!
Old Feb 9, 2013 | 09:31 PM
williala's Avatar
williala
Get the air bags, they are so much more versatile than springs. You have and almost limitless adjustment on weight bearing settings, allowing you to match your spring rate to your load. They also allow you much more control, as you can eliminate sagging by just adding more air, which gives you a lot more control when you are driving.
And when not carrying a heavy load you can let out air to give a smoother ride.
Old Feb 9, 2013 | 10:06 PM
horatio102's Avatar
horatio102
I find I have to run about 30-35 psi in my bags to keep from slapping my factory overload springs on their perches.
Old Feb 9, 2013 | 11:04 PM
rracer5's Avatar
rracer5
X3 on the air bags. I've heard of several 5th wheel rv'ers who have installed the Firestones and rave about them. I will be getting them when I upgrade to a 5th wheel.
Old Feb 10, 2013 | 03:06 PM
horatio102's Avatar
horatio102
I put the firestones on to help with sag on my bumper pull.
Old Feb 10, 2013 | 03:28 PM
Kyle2012RAM
That's what I was liking about the air bags williala. Ill probably go with the air bags. Thanks guys
