1999 3500 5spd
I got one. check my sig. 140k on it and love it. 20+mpg unloaded and pulls like crazy when loaded. It would be better with 4wd in the winter but chains solve all of my problems and are a whole lot cheaper to maintain than 4wd.
As far as the 5sp ..it works good. I don't abuse it and stay away from 1800 rpm when towing as much as possible. With the 4.10 gears I don't really need to load it up in the gears. It will go up almost any hill in 4th and most in 5th at 2000 rpm.
I've been told that the input shaft needs to be replaced with the larger 1 3/8 as well as upgrade the clutch but so far I've not had one bit of trouble. A buddy has already had syncro in his 6spd at 75 k.
There is an upgrade aftermarket kit available for the output shaft and 5th gear but I haven't got that far yet. Maybe next year.
