01 24 vavle turbo problem
Old Apr 10, 2013 | 10:35 AM
pipeliner798's Avatar
pipeliner798
Default 01 24 vavle turbo problem
i just bought an 01 dually welding rig and it drove awesome till this morning going down the road went to shift into 3rd (5 speed manual) and i felt like it got kicked in the nuts. i couldnt hear my turbo and i had no boost. what r some simple problems that would make my turbo stop working. had an edge programmer on it till the guy i bought it from had a new fuel pump put on and in order to save the warranty had the mechanic leave it disconnected.
Old Apr 10, 2013 | 11:37 AM
Jigabop's Avatar
Jigabop
do you have gauges?
if not, get them.
you need fuel pressure (0-30psi mechanical), EGT, and Boost (0-40psi or 0-60psi should do)
gauges will tell the story better...
sounds like its not getting fuel though. any engine codes?
fuel makes boost. no fuel, no boost. simple as that unless a bearing went or something got jammed in it, but either of those would be VERY noisy and obvious.
Old Apr 10, 2013 | 06:18 PM
pipeliner798
talked to a buddy he said lift pump thanx for the help
