Questions on 2013 Cummins fuel mileage
Old Apr 28, 2013 | 11:52 PM
peteinnw's Avatar
peteinnw
Default Questions on 2013 Cummins fuel mileage
Anybody know what kind of mileage the 2013 Cummins 6.7's are getting with DEF?
Also wondering if going to the 6 speed manual and 2WD helps mileage?
Can't seem to find this information anywhere. Your help is much appreciated!
Old Apr 29, 2013 | 09:39 AM
jasonw's Avatar
jasonw
Site Moderator
I will move you to the diesel section.
For future reference:
https://dodgeforum.com/forum/dodge-r...s-section.html
Old May 2, 2013 | 11:32 AM
cyclone429's Avatar
cyclone429
Ctd with a 6sp man have lower hp and tourqe than automtics...as for mpg, empty or towing 2wd or 4wd its the driver whos going to influence mpg numbers.
I prefer the 6sp man...all hd rams now have 342 rear end gearing as for def fluid, I doubt thier are nanny 2013 rams roaning the highways as thier are a lot of idel 2012 on dealer lots..
Old May 2, 2013 | 12:46 PM
DodgeCACares's Avatar
DodgeCACares
Peteinnw,
Fuel mileage is going to get better with the DEF and there are less moving parts with the 2WD so there should be less fuel usage. However, since vans, pickup trucks and SUV's weighing more than 8500 pounds gross vehicle weight are classified as heavy-duty vehicles, fuel economy regulations do not apply. These vehicles are not tested and fuel economy labels are not posted on the window sticker.
As Cyclone429 mentioned, the actual mileage you can expect depends on the individual driving habits of the person using the vehicle, the conditions under which it is driven and the vehicle’s mechanical condition.
Old Jun 4, 2013 | 03:01 PM
BrianHaines's Avatar
BrianHaines
Smile 2013 Ram 2500 Fuel milage
I just bought a new 2013 Ram 2500 mega cab 4x4 with the auto trans and 3.42 gears. This model has the def. truck is lifted and has 37"x13.5x20 Toyo m/t tires. I am pleased to say that i am getting between 16 and 17mpg! I think if this was a stock truck you would see it in the 20+mpg. Ive only got 1500 miles on it so it may get better when its broke in.
Old Jun 4, 2013 | 03:12 PM
Jigabop's Avatar
Jigabop
hope your DEF system doesn't fail...been hearing a lot of horror stories already trucks will less than 3k miles having to replace the DEF system because it failed...and dealers trying to blame the owners for it when it was not the owners fault...
