Air Conditioning Just Stopped Working
Old May 30, 2013 | 12:59 PM
TitansFan's Avatar
TitansFan
Default Air Conditioning Just Stopped Working
My air conditioning has suddenly stopped working. The light comes on when I press the AC button, but no cool air. What steps should I take to determine what the problem is? I've added coolant before on other cars, but not this truck (if that's the problem). Thanks!
BTW, the truck is NOT what is listed in my signature. It's a 2007 2500 with a 5.9 CTD.
Old May 30, 2013 | 06:53 PM
Uncle Meanie's Avatar
Uncle Meanie
Start the truck and open the hood.
Turn on the AC and check to see if the compressor clutch engages, if not start looking at fuses and wiring connections if possible.
If the clutch does engage, find the line that heads from the compressor to the condensor (Radaitor) and CAREFULLY touch it. It should be hot to the touch as that is a compressed gas that needs to cool. If it is just warm then you may need to recharge the system.
You can also find the any exposed metal on the suction line coming from the cab area to the compressor and see if it is cool or sweating. If so, you should have at least some refrigerant in the system.
Start there and let us know what you find.
Old May 30, 2013 | 07:47 PM
p38251's Avatar
p38251
Ensure the condensor fan is working as well.
Old May 31, 2013 | 09:12 AM
TitansFan's Avatar
TitansFan
Thanks! I will check after work and post what I find out.
Old May 31, 2013 | 12:48 PM
DodgeCACares's Avatar
DodgeCACares
TitansFan,
Keep us posted on the outcome. If you are still having issues and are seeking additional assistance or would like me to review if there are any recalls that may be related please PM me and I'd be happy to help!
Old May 31, 2013 | 01:02 PM
Jigabop's Avatar
Jigabop
check if the compressor is engaging while ac is on max.
if no engage, then unplug the sensor on top of the dryer (aluminum bottle with aluminum lines and a sensor on top that is attached to the firewall) and jump the sensor cord connections with a paperclip and see if the compressor comes on at that point. report back once you get that far...
Old Jun 5, 2013 | 04:27 PM
Uncle Meanie
Hey TitansFan, Did you get the A/C working?
It is nice to have a little closure on these posts for future searches.
