Dual Mass flywheel help
Old Jul 9, 2013 | 10:13 PM
vegasvaughn's Avatar
vegasvaughn
Default Dual Mass flywheel help
2006 Dodge ram 2500 5.9 6speed manual
I think my dual mass flywheel is bad. Has anyone converted to a solid single mass?
What are the pros and cons off each?
Which is a good brand to buy?
Will the original factory clutch work with a solid single mass flywheel?
Old Jul 9, 2013 | 10:51 PM
horatio102's Avatar
horatio102
A lot of guys go with a South Bend setup.
Old Jul 9, 2013 | 11:17 PM
vegasvaughn
i just put in a new clutch from the dealer. If i change to a single mass solid flywheel, can i keep the clutch i just installed?
Old Jul 10, 2013 | 10:06 PM
horatio102's Avatar
horatio102
You can keep it, but I don't think you'll be able to use it. Call South Bend and ask.
Old Aug 20, 2013 | 04:44 PM
Frieslander's Avatar
Frieslander
from everything that I have read and heard - get rid of it. The big names such as centerflex, and southbend are expensive. phoenix friction products sells a complete kit for considerable less (find them on the web) you can go with a stock upgrade or choose one of several different pressures. Kits come with fly wheel pressure plate clutch throw out bearing pilot bearing master and slave cylinder and I think the yoke is also included. Haven't done mine yet but its on the books to be done.
Old Aug 20, 2013 | 11:16 PM
scatpack_69's Avatar
scatpack_69
Southbend or Valair are all I would run, nothing else. Stock dual mass sucks.
Old Sep 29, 2013 | 06:13 PM
dan983's Avatar
dan983
Phoenix 480 HP organic kit! Works terrific. You will have to endure gear roll-over noise. Consider replacing the ATF4 tranny fluid with the Mercedes spec Mobil Delvac synthetic 50 weight oil.
Old Sep 29, 2013 | 06:48 PM
Gone Fishin's Avatar
Gone Fishin
Call South Bend, they'll build a custom setup based on what you intend to do with your truck------I've had one in my gas engine for well over 100K miles and no problems yet
