1997 Dodge Ram 3500 Diesel 4x4 dually
Old Oct 13, 2013 | 08:09 PM
donald_hill's Avatar
donald_hill
Default 1997 Dodge Ram 3500 Diesel 4x4 dually
Today I found that I do not have the power to pull my trailer up hills that I have never had a problem with before. What could the loss of power be caused from? I have been pulling the same trailer for years without difficulty like I had today.
Old Oct 14, 2013 | 01:01 AM
horatio102's Avatar
horatio102
losing fuel pressure? Losing boost pressure?
Old Oct 15, 2013 | 11:53 AM
donald_hill
I am thinking boost pressure, but have no idea. Mechanics is not my things. Just wanted some sort of an idea before I took in to a Dealership Thank you
Old Oct 15, 2013 | 04:28 PM
Jigabop's Avatar
Jigabop
do you have gauges on it?
you can check for boost leaks by building a boost leak detector...
basically a rubber reducer boot with clamps that fits the turbo inlet, a threaded pipe plug that fits the other end of the boot, some PVC glue to glue the pipe plug into the end of the boot and clamp it down so the thread plugs bite into the rubber. (glue gets used as a sealent/lock tight) then drill and tap the end of the pipe plug and put an air compressor fitting on it so you can hook an air hose to it, and set your compressor regulator for 5-10psi. put air to it and use a squirt bottle and check all vclamps, pipe and intercooler boots, and intake gaskets for air leaks.
this is my boost leak detector for my twins:
cost me all of $13 at home depot to make.
