Blown Tachometer
Old Nov 15, 2013 | 02:11 PM
pedrugge's Avatar
pedrugge
Question Blown Tachometer
My tach has blown up. It was coming on and off at random. The other night, the accelerator got stuck wide open and the tach needle went all the way around. Now it's pinned under the little stake at 0 rpm. That truck has some serious revs!!
What kind of a job is it to replace the tach? Should I go to the dealer and if so, does anyone have guess estimate as to cost?
2006 Dodge Ram 2500 diesel.
Old Nov 15, 2013 | 08:34 PM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF. Will move you to the correct spot.
For future reference:
https://dodgeforum.com/forum/dodge-r...ead-first.html
Old Nov 16, 2013 | 10:58 AM
pedrugge's Avatar
pedrugge
Thumbs down Where is my thread?
I posted after registering all over again with the same password and username.
Then I gotr a response. I asked a question in response. Now that is missing and all I have is a message that says I'll move youto to the right spot.
Not making much progress here.
Old Nov 16, 2013 | 04:44 PM
mega cab ram's Avatar
mega cab ram
Press and hold the odometer rest button turn key to on (do not crank). Release odo rest and let the gauges calibrate.
This may temporarily fix the issue but if your truck is an '06 then you probably have a faulty stepper motor on the tach.
Old Nov 16, 2013 | 07:49 PM
pedrugge's Avatar
pedrugge
Thank you. I'll try that in the morning.
Old Nov 17, 2013 | 11:54 AM
pedrugge's Avatar
pedrugge
Well, I'll be darned! That worked just fine. I know that many '06's have that problem. I called the dealer and he said I'd have to bring it in. They would have done what you said and charged me big bucks for doing the same thing.
I thank you vey much!!
Old Nov 18, 2013 | 10:41 AM
mega cab ram
I'm glad that worked for you.
