gasoline in Cummins
Old Oct 16, 2005 | 11:51 PM
ZR900's Avatar
ZR900
Default gasoline in Cummins
My daughter put 21 gallons of gasoline in a buddies 36 gallon diesel truck tank and ran it till it needed a tow truck. I understand it will reach 55 mph but ran rough. It's a 2004 Cummins. What is likely to have happened to this engine if anything? It has not been drained and restarted yet. Thanks for any help.
Old Oct 17, 2005 | 01:23 AM
Saint's Avatar
Saint
Default RE: gasoline in Cummins
Lift Pump, Injection Pump, and all 6 Injectors are more then likely toast. Those are the parts that are going to be effected the most by putting gasoline into the fuel system.
Old Oct 17, 2005 | 01:36 AM
thump186's Avatar
thump186
that would be a good start added the cost of draining the tank, flushing the system,fuel filter oil change ect...
Old Oct 17, 2005 | 03:06 AM
ZR900's Avatar
ZR900
No other issues? Wouldn't most of the problems be lubrication related?
I was on a trip when a guy filled his almost empty brand new Ford completely with gas. It quit within a mile or so. Drained and refilled. No damage.
This Cummins had a 60/40 mix in it and ran for an hour. What are the chances it will be OK? Any chance?
Let you know how it turns out tomorrow.
Old Oct 17, 2005 | 03:18 AM
Flent's Avatar
Flent
ouch....
Old Oct 17, 2005 | 09:06 AM
thump186's Avatar
thump186
There is a chance that it will be fine but better off looking to the worst side of it and being prepared for it.
Old Oct 17, 2005 | 10:22 AM
Drew's Avatar
Drew
once the mogas is drained and the system primed back up with diesel you will be able to better tell what kind of damage is done.
I doubt any damage took place. these engines are very resielant and can take alot of abuse before something breaks
Old Oct 18, 2005 | 02:22 AM
Saint's Avatar
Saint
That is true what Drew said, it really is hard to seriously hurt a Diesel, unless there is a flaw in the design. However I always look to the worst case scenario first to prepare myself . Like Drew said once you drain, flush and prime the system, you'll know a lot more.
Old Oct 18, 2005 | 10:53 PM
ZR900's Avatar
ZR900
No damage. Runs fine. Tough engine. Thanks for the help.
Old Oct 19, 2005 | 10:03 AM
Drew's Avatar
Drew
good to hear
