Clear codes? P2609
Old May 6, 2014 | 11:38 AM
7lazy77's Avatar
7lazy77
Default Clear codes? P2609
Tried searching, but for some reason (probably my own) I couldn't come up with anything on how to clear the codes on a 4th gen truck. Do I just disconnect the 2 ground cables for 5 minutes trick?
I am getting a P2609 Generic code (Intake Air Heater System Performance). After a little research on the code, I am going to check & clean all connections & would like to see if it still throws the same code.
Old May 6, 2014 | 06:12 PM
bluebeast1562's Avatar
bluebeast1562
Default RE: Clear Codes?
Not really sure if disconnecting the battery cables will help, I know that if you take to Autozone or Advanced Auto and they run the scan tool, they will not clear the codes for you however, when I asked about it a while ago, they said "Here, see this button, press it and it will clear the codes" all while they looked away.
Old May 6, 2014 | 06:33 PM
Greatrack2012's Avatar
Greatrack2012
What I Did for my Dakota was, run the code reader to clear the the check engine light. Then disconnected the battery for maybe a 1 min then hooked it back up. Should work for your truck.
Old May 6, 2014 | 08:22 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
That DTC is probably erroneous. There was a STAR case where it stated they were developing a software update for overly sensitive diagnostics. It was not dated, so you may want to check with the dealer and see if there is a flash available on the scan tool.
TSB 18-005-13 was the latest mentioned for the flash.
I'm going to move your thread to the Diesel truck section, as that is a Cummins DTC and I assume you have a 2500 ?
Belated Welcome to Dodge Forum, BTW
Old May 7, 2014 | 12:23 AM
7lazy77's Avatar
7lazy77
Thanks for the information....and yes, it is a CTD 3500.
Old May 7, 2014 | 11:39 AM
Jigabop's Avatar
Jigabop
disconnecting battery cables isn't going to clear any codes. This isn't the 80's or early 90's lol. ECM's these days store everything to non-volatile memory. kinda like your computer saves things on its hard drive...it isn't going to lose that memory when you take power away...
