Advice: swapping a 1998 12v with a 1999 24v
![Cool](https://dodgeforum.com/forum/images/icons/icon6.gif)
Just curious, what all would be involved with this project. I'm swapping out a 1998 5.9 12v with a 1999 5.9 24v from bus. Give me some advice and pointers if you guys dont mind.... PCM, Pump, harness???? What all is universal and what all will i have to swap or replace to be a successful build?? Thanks guys!!
![Icon Bricks](https://dodgeforum.com/forum/images/smilies/icon_bricks.gif)
24v's have a vacuum pump.
If it's the same guy that posted on cumminsforum, one of the trucks is 4x4 and the other is not. he wants to build the 4x4 into a race truck and the 2wd as a daily driver... I forget which is which but it sounded like he wanted the 24v to race with? don't really see the point in the swap when a 12v can be built up just the same as a 24v... hell put a race head on it if you're really worried about flow from the valves...
the most powerful performance v8 piston engines in the world only use 2 valves per cylinder... and those are the 10,000hp top fuel dragsters...
