Need help! Swap!
Old Dec 12, 2014 | 08:24 PM
ProjectTwinTurbo's Avatar
ProjectTwinTurbo
Default Need help! Swap!
Well I'll start by saying I have a 2000 2500 dodge ram. BUT it has a 360 magnum. Today found a heck of a deal on a 24v Cummins. I need help on what I need to make it work. I don't need to know the drivetrain part of it.
Just the FUEL, WIRING, AND GAUGES, ETC. Any input you guys have will be greatly appreciated.
Old Dec 13, 2014 | 02:49 AM
horatio102's Avatar
horatio102
Get the whole truck. That way you'll have everything you need. And contemplate letting your insurance company in on what you've done. Not a whole lot worse than dumping a bunch of money into a truck then getting a loss claim paid out for pennies on the dollar because your insurance isn't up to snuff.
Old Dec 13, 2014 | 10:55 AM
ProjectTwinTurbo
I'm not worried about Insuramce and stuff. I can't buy the whole truck. Guys had this motor for 5yrs now stored. Everything's there and its bored .020 over. Just needs put together. Only cost me 300$. So that's why I'm going this route. Just need input on what I'm gna need b4 I go and buy it and be stuck. I know k need
Harmesses. What ones?
Transmission
Mounts
Insturament cluster
And so on.
Another question. While its there. What else should I replace b4 I put it together?
Old Dec 15, 2014 | 11:27 PM
horatio102's Avatar
horatio102
trans, driveshafts, front end (unless yours is a HD v8 with a 60 up front already), rear end, springs, cluster, dash harness, engine/trans harness, ECM/TCM, fuel tank/sender, lines, filler neck.
Old Dec 16, 2014 | 08:05 AM
ProjectTwinTurbo
The fuel tank wouldn't be the same? Cause ik someone that has a 24v which is what I'll go off of ams they look alike.
Old Dec 16, 2014 | 08:16 AM
ProjectTwinTurbo
I mean of course the pumps are different. But 24v have like the external pump. So couldn't I use the factory one as a sending pump?
Old Dec 18, 2014 | 01:23 AM
horatio102's Avatar
horatio102
I don't know if the tank itself is different, the factory setup on the diesel would have been a block mounted electric pump with just a sender in the tank. The problem is that the electric pumps don't like heat and vibration, so being mounted to the engine didn't work out so well. As a revision, they moved the pump into the tank.
A better solution is a frame mount pump with either the factory sump or a draw straw.
I believe a gas truck's pump would be in the mid-40 psi range, and a 24v wants to see 14-20psi max.
Old Dec 19, 2014 | 01:56 PM
ProjectTwinTurbo
Really appreciate the reply. Would a regulator on the line work?
Old Dec 21, 2014 | 12:38 AM
horatio102's Avatar
horatio102
It may, but I'm also not sure if the volume would be sufficient, or the return system, the vent system, etc. Or if there's a difference in pump/sender materials due to the difference in fuels.
It really would be best to get a diesel draw straw with sender and a frame mount pump.
Old Dec 21, 2014 | 11:08 PM
ProjectTwinTurbo
Alright thank you
