High Readings on the Oil Pressure Gauge
Old Mar 30, 2015 | 08:32 PM
Cummins1999's Avatar
Cummins1999
Default High Readings on the Oil Pressure Gauge
I have a 1999 Dodge Cummins. When I started it up today the oil pressure was reading a little over 40 and when I started driving it was on the max line for PSI. After the engine warms up completely the pressure will return to normal. It usually runs a little under 40 at idle and a little over 40 while I'm driving. Has anyone else had a problem like this or know what could be going wrong.
Old Mar 30, 2015 | 08:34 PM
Moving to the correct section. Please read the section descriptions so you post in the proper area.
Old Mar 30, 2015 | 08:35 PM
Cummins1999
Thanks man which section should I put this under next time
Old Mar 30, 2015 | 08:37 PM
This one. Diesel specific. This gets you in the section with the experts. Welcome to DF.
Old Mar 30, 2015 | 08:38 PM
Cummins1999
Thanks man haha first time using this website
Old Mar 30, 2015 | 08:42 PM
No worries. It's laid out pretty straight forward. Just read what each section is about. Look around. Lots of good info and good people here willing and wanting to help. Also check out the 2nd gen Ram section that's probably the most active section here. You can also post questions there about your truck.
Old Mar 30, 2015 | 10:29 PM
p38251's Avatar
p38251
Try a direct reading gauge.
Old Mar 31, 2015 | 02:21 PM
Cummins1999
do you know what could be causing this problem
Old Mar 31, 2015 | 07:24 PM
p38251's Avatar
p38251
Could simply be a bad sending unit. Direct reading gauge will let you know if its more serious.
