Wont start when cold unless plugged in
Old Oct 18, 2015 | 08:13 PM
Brett Fritzsch's Avatar
Brett Fritzsch
Question Wont start when cold unless plugged in
Truck info:
-2005 Dodge 2500 Diesel
-137,000 miles
-Oil and Fuel filters changed within 3000 miles
Essentially what is happening is that the truck starts perfectly fine when it is 60+ degrees out and barely cranks before it kicks over. Also the 'Wait to Start' light stays on for less than 5 seconds which from what I can tell from the tables posted all over the place (http://dodgeram.org/tech/dsl/trouble...niford_htr.htm).
I did troubleshooting based on a lot of the different articles that I found from searching 'Dodge Diesel Grid Heater problems' or 'Dodge diesel hard start', etc. Here is what I have done up until this point:
-Replaced both relays
-Replaced Grid Heater
-Listen for clicking noise (supposedly relays/grid heater being utilized) and its there, louder since replacing heater and relays
-Testing voltage and resistance of relays and both are what the troubleshooting articles say they should be
-Tested voltage when truck key is turned on at the 'Output to Heater' posts on both of the relays and they show 12V and go back to 0 when shut off.
-Tested voltage when truck key is turned on at the 'power' terminals on the grid heater and both show 12V and go back to 0 when shut off.
-Tested before/after temperature of grid heater by touch and infrared temp gun in both scenarios you could tell it was significantly warmer and the 'red horn' temperature above the grid heater was significantly higher.
The problem is this morning it was around 35 degrees fahrenheit and it would not start. I turn the key to the on position and the 'wait to start' light stays on for right around 10 seconds or so then goes off. I then attempt to start the truck and hold it for 10 seconds and still no luck. Let it sit for a couple minutes to let starter cool down and then try again and same results. I end up having to plug the truck in for an hour or so and then it starts up right away as if it were 60+ degrees outside.
Any suggestions on where I should be looking next?
Old Oct 18, 2015 | 08:25 PM
p38251's Avatar
p38251
It could be the heater grid is not getting hot enough. Your batteries good?
Old Oct 18, 2015 | 08:27 PM
Brett Fritzsch
I bought this truck used off of someone 4-6 months ago and was told the batteries were both replaced within the last two years. I have not had any other issues related to make me think batteries are weak. Both seem to test fine at advanced auto parts and charge and stay at the 14 mark when truck is running.
Old Oct 18, 2015 | 11:07 PM
CopenghagenHemi22's Avatar
CopenghagenHemi22
possibly bad fuel or something else causing it when it starts to get colder out. Also, when its real cold and my truck isn't plugged in, I will cycle the key on and off and let it "wait to start" a few times. Not really sure on this one.
