Fuse box
Old Dec 7, 2015 | 10:38 PM
Greensburg's Avatar
Greensburg
Default Fuse box
I have a 2001 dodge diesel I have power to the fuse box and that is it no power no were I mean no were inside and out and it and it got NO BUST
Old Dec 11, 2015 | 12:12 AM
horatio102's Avatar
horatio102
Bad main fuse?
Old Mar 25, 2020 | 09:35 AM
GrayHat's Avatar
GrayHat
Just an update, sorry took so long to post the solution to this issue, but I had the alternator cable from the fuse box to the battery not hooked up on the B+ terminal. Which I figured out from the diagrams. But even then when I hooked it up, the alternator continued to over heat - and I still had the extra cable from the wiring harness which is not represented in the 96-97 service manual, nor other people's trucks that I looked at. I do not know why I have it, but it counts as a ground... As one can see from the diagram, and based on the size of the cable, who would ever expect this to be a ground?
Anyone able to explain this to me? Its running now.
Not the same wiring as mine
Alternator Cable not Seen
