leaking power steering
Old Nov 9, 2005 | 03:05 PM
bigmike's Avatar
bigmike
Default leaking power steering
hey folks,
my buddy has an '01 3500 4x4 that leaks power steering fluid like water hose. there are no evident cracks or holes( so he says), and as he does not have internet, he asked me to see if anybody has this issue with a second generation ram, and if there is a cheap solution. he has tried some form of stop leak for power steering, to no avail. i believe the answer is he needs to get a new power steering pump, but he would rather have more opinions than mine.
thanks,
Old Nov 9, 2005 | 04:59 PM
Drew's Avatar
Drew
Default RE: leaking power steering
I would take a look and see if there are any cracks around the timeing cover or any parts that are connected to the vacuum pump. it could be a seal that has gone bad.
if it is the vacuum seal it is something that does go out and can be replaced easily, but is not a common issue. a new seal kit runs less than $9 (4089742) from Cummins. . .or $65 from Dodge with the same Cummins part number
Old Dec 4, 2005 | 04:42 PM
grunt's Avatar
grunt
Hi BIG Mike, I just had a leak in power steering pump. Problem was leak in pressure hose that also is for brake boost since there is no vacuum in a diesel. Also your steering will be very hard at startup hope this helps. Frank
Old Dec 26, 2005 | 09:18 PM
srenken's Avatar
srenken
You did not say where the leaking was coming from. Power steering fluid and automatic transmission fluid are the same. On diesel and 3500 gas dually, the brake system uses what is called a hydoboost system made by Bosch. The power steering pump sends fluid into your brake booster, and into your steering gear. Trace the lines, and make sure there is no leaking from the lines. Use a piece of white paper, and stick under the brake booster, and see if the power steering fluid is leaking out of there. You have two high pressure hydoboost hoses that come out of the brake booster, and a pressure hose that goes to the steering gear.
Old Dec 28, 2005 | 05:58 PM
bigmike's Avatar
bigmike
thanks
i will get with my buddy and do some checking on that.
