Help a girl fix her dad's truck?
Old Apr 24, 2018 | 03:48 PM
Turbo lag??????
Originally Posted by jkeaton
Will this work on your truck?
https://www.youtube.com/watch?v=3GqCsfmCTuE
Give it a shot, and see what happens. If you can get the codes, it may point us in the correct direction.
Old Apr 24, 2018 | 03:50 PM
Shawnah's Avatar
Shawnah
When it starts to accelerate on its own and you put it in neutral, does the engine continue to rev? Need to know the code in order to properly assist you, otherwise we are just guessing.
it only showed one code: P0700
Old Apr 24, 2018 | 03:52 PM
TCM....thats a tough one....
Old Apr 24, 2018 | 03:53 PM
Shawnah's Avatar
Shawnah
I mean the engine. Does the engine speed continue to increase when you put it in neutral. Not if the vehicle comes to a stop.
That's what I meant, the speed does not continue to increase and the engine stops making it's intense roar. It sounds like you have the pedal to the floor until you throw it in neutral
Old Apr 24, 2018 | 03:58 PM
Shawnah's Avatar
Shawnah
there is no drain on the transmission is there? Just have to drop the pan carefully and let it go out one corner?
Old Apr 24, 2018 | 04:02 PM
OK, apparently, the PCM sets that code when the TCM (trans control module) has set a code..... but, to read THOSE codes, you need a fairly high-zoot scanner.
Now, I have no idea why a trans fault would cause the engine to be stupid. That's just strange.
Going to need to get your hands on a good scanner, that will actually read the TCM codes, and see what IT thinks is going on......
Old Apr 24, 2018 | 04:03 PM
Shawnah's Avatar
Shawnah
I appreciate it, I'll see what I can figure out
