p2271, p2a01,p013a,p2bac
Old Jun 21, 2018 | 10:58 AM
edwood1's Avatar
edwood1
Default p2271, p2a01,p013a,p2bac
2011,3500 diesel codes
Old Jun 21, 2018 | 02:41 PM
P2271- O2 Sensor Signal Stuck Rich Bank 1 Sensor 2
Does the diesel even HAVE O2 sensors?????
P2a01 refers to an error on the same sensor.....
P013a is slow response, from the same sensor.....
P2bac is nox Exceedence - Deactivation of EGR
NOX is high. Why becomes the question. Think I would replace the sensor in question, clear the codes, and see if everyone is now happy.
Old Jun 22, 2018 | 12:58 PM
edwood1's Avatar
edwood1
Thanks. I replaced the sensor in question and p2bac code comes back?? p2271 is still permanent and all other codes dissapeared
Old Jun 23, 2018 | 08:23 AM
Does your truck use DEF? Is the tank empty? How many miles on it??
Old Jun 23, 2018 | 05:59 PM
edwood1's Avatar
edwood1
thankyou for your help.
No DEF.100,000km
Old Jun 24, 2018 | 08:56 AM
Likely going to be a wiring problem then. I suspect the other two codes will come back eventually as well....... Of course, it may also be a fueling problem, but, I would expect to see different codes for that...... Diesel really isn't my strong suit though.... so, hopefully someone with more of a clue will be along.
