Multiple OBDII codes
Old Oct 4, 2018 | 09:47 PM
b1mac's Avatar
b1mac
Default Multiple OBDII codes
2012 Ram 4x4 Larime 6.7L
I did a obd scan and had multple codes come back.... Lots for both passenger and drivers door, Nav is also stuck on boot screen. Could this be a electronic card casing this? Any insight would be greatly appreciated.
1 Wireless Control Module Trouble Codes:
• B1A79: STORED - Remote Start Antenna Circuit Open/Not Connected
1 Front Control Module (Central Gateway) Trouble Codes:
• B1630: ACTIVE - Right Low Beam Control Circuit High
5 Drivers Door Module Trouble Codes:
• B21A1-00: ECU Reset/Recovery Occurred : No Sub Type Information
• U0164-00: Lost Communication With HVAC Control Module : No Sub Type Information
• U0209-00: Lost Communication With Memory Seat Control Module : No Sub Type Information
• U0155-00: Lost Communication With Cluster/CCN : No Sub Type Information
• U0141-00: Lost Communication With IPM (FCM/TIPM) : No Sub Type Information
6 Passengers Door Module Trouble Codes:
• B1D2A-11: Passenger Mirror Vertical Motor Control Circuit/Performance : Circuit Short To Ground
1 Cabin Compartment Node (Instrument Cluster) Trouble Codes:
• P0953: STORED - Auto Shift Manual Control Circuit High
3 Radio Trouble Codes:
• B142D: ACTIVE - Audio Antenna Not Connected
• B157B: ACTIVE - Satellite Region Mismatch - US/Canada
• P0294: Cylinder 12 Injector "A" Circuit Low
Old Oct 4, 2018 | 10:17 PM
Try disconnecting the battery(s) for a bit.
