Tps??
Old Aug 10, 2019 | 05:06 PM
5.9_MAGNUM_POWER's Avatar
5.9_MAGNUM_POWER
Default Tps??
95 12v Cummins. As soon as I let off the throttle the truck shifts into third and shortly after downshifts to second. It acts like it’s in tow haul mode, but it obviously doesn’t have it. Could it be the TPS??
Old Aug 10, 2019 | 06:07 PM
It should have tow/haul mode.... Its the O/D off button on the dash. If the PCM is disabling O/D for any reason, the light on the switch should come on.
The first three gears in your trans are purely hydraulic control. If it isn't shifting right, make sure the TV cable is properly adjusted, and moves freely. Otherwise, it's going to be an internal problem.... When is the last time the fluid/filter was changed? Bands adjusted??
Old Aug 11, 2019 | 08:16 AM
5.9_MAGNUM_POWER
It upshifts just fine and when it downshifts I just re apply the throttle and it goes back to normal. It only downshifts when I let off the throttle
Old Aug 11, 2019 | 09:33 AM
How much of an rpm drop?
Old Aug 11, 2019 | 01:54 PM
5.9_MAGNUM_POWER
I don’t understand what you are asking?
Old Aug 11, 2019 | 03:20 PM
If you drive in a straight line, at a steady speed, (fast enough that O/D is actually engaged.) and you just move the pedal a bit, does the tach bounce? If so, how much?
Old Aug 12, 2019 | 07:31 AM
5.9_MAGNUM_POWER
The tach doesn’t really bounce. if I let my foot off just enough it will downshift into third.
Old Aug 12, 2019 | 09:19 AM
It shouldn't downshift when you let off the gas, unless you slow dramatically. Check TV cable for proper operation/adjustment. If that doesn't help, time to visit a trans shop, and have them check pressures.
