Wheels and tires
Old Dec 18, 2005 | 11:01 PM
TurboRamm's Avatar
TurboRamm
Default Wheels and tires
I have a 2003 Dodge Cummins 2500. I want to stick a 2 inch leveling kit on the front. What size of tire can I fit (stock) with no body lift or suspension lift.
Thanks
Mr. David
Old Dec 19, 2005 | 02:48 PM
tommiwan's Avatar
tommiwan
Default RE: Wheels and tires
Leveling kit should give you the ability to fit 35's
Old Dec 27, 2005 | 05:22 AM
hometheaterman's Avatar
hometheaterman
I'd think you could fit 35"s with little to no rubbing.
Old Jan 10, 2006 | 10:45 PM
cumminpower's Avatar
cumminpower
I JUST TOOK OFF MY STOCK TIRES AND RIMS ON 03 2500. I PUT 17 X 10 RIMS WITH 33 / 70 / R17 TIRES. I DIDN'T HAVE TO PUT LEVELING KIT ON, BUT I DID TO MAKE IT LOOK BETTER. IF YOU GO ANY BIGGER YOU MIGHT GET SOME RUBBING IF YOU HIT A BUMP.
Old Jan 11, 2006 | 06:41 PM
bigmike's Avatar
bigmike
i have an 04.5 2500 4x4. i put a 2 inch leveling kit on it and i run 33x12.50/17's on it. i researched and asked questions before i put the leveling kit on it, and was told by 2 different companies that yes you can run 35's but on turns with the suspension compressing, you may rub. it wasn't worth it to me to run the risk of damage.
