Ram 1500 eco-diesel 2022 limited 4x4 with split tailgate
The other day, my kids and I were sitting on the tailgate chatting. Apparently my daughter fiddled with the tailgate latch on the short side (right side, if looking at it from behind) of the split tailgate, and she latched it shut while the tailgate was down. I didn’t notice this until I put the tailgate up and the left side locked closed and the right side didn’t - because the latch was already closed. Now, I can’t get the tailgate to drop nor can I get the right side latch to reopen. Is there a way to manually open the right side latch/locking mechanism?
Thanks in advance for any help.
Yep. Pull the plastic pins on the OPPOSITE side of the jammed up latch. The cover should come off, and there may or may not be another panel under there you will have to remove. Once you have access to the latch, you should be able to release it manually.
It's also possible that you could remove the two torx-bit screws holding the latched latch in place, and that will relieve the stress on the tailgate, and you might be able to pull the handle, to get it to release. (Think I would try that method first....)
