Thought on Transfer Pumps
Old Feb 12, 2006 | 10:08 PM
Bikertrash's Avatar
Bikertrash
Default Thought on Transfer Pumps
It seems funny to me that fuel injected cars run high pressure electric pumps well over 100k miles, while the Cummins tranfer pump lasts about half as long. Gas does not lubricate as well as Diesel.
I wonder if the engine vibration is what kills them. I am toying with the idea of relocating the transfer pump to the inner fender or some other location away from the engine. What do you guys think?
Old Feb 13, 2006 | 05:09 PM
Drew's Avatar
Drew
Default RE: Thought on Transfer Pumps
that has been a though many have looked at as to the reason the lift pump dies. Either that, or it's cheap, or it might be that diesel is a bit thicker than gas, thus the pump has to work harder.
anyway, you cannot go wrong with a fass or some other system which usualy mounts on the frame away frrom the ruckus of the engine.
Old Feb 13, 2006 | 06:10 PM
Bikertrash's Avatar
Bikertrash
Tell me more about the fass. What is it and where do I find it?
Old Feb 14, 2006 | 07:15 PM
Drew's Avatar
Drew
the FASS pump is a better, higher volume pump for our trucks. it comes in two models configured in two different ways, the FASS-I comes in a 95 and 120gph pump with it's own filtration. the FASS-II does not have filtration.
if you want to know more just type FASS into a google search
Old Feb 14, 2006 | 08:40 PM
Bikertrash's Avatar
Bikertrash
Thanks!
I have an old Mallory Comp Pump. It is a geroter type pump rated at 120 gph with a 6.5 psi pressure relief. I'm don't know how much pressure I should have or if I should use this pump on diesel fuel. It was designed to supply high performance carburated gas engines.
Paul
Old Feb 15, 2006 | 06:51 PM
Drew's Avatar
Drew
no more than about 16PSI pre injector pump.
the stock LP will keep from 16-12PSI pre injector pump and can be drawn down to about 0PSI apun WOT
Old Feb 15, 2006 | 07:42 PM
Bikertrash's Avatar
Bikertrash
Thanks!
I think I'll try frame mounting a high performance automotive pump. They are a lot cheeper than some of the aftermarket diesel solutions I have looked at.
Old Feb 15, 2006 | 08:08 PM
Drew's Avatar
Drew
they may be cheaper in comparison, but remember, Diesel fuel is a good bit thicker than Gas
Old Feb 15, 2006 | 10:55 PM
Irish4u1978's Avatar
Irish4u1978
On my brothers 01 the lift pump lasted almost 200k, then he replaced it with the fass pump. A bit loud, but you know its working (or at least making noise)
Old Feb 16, 2006 | 12:13 PM
Bikertrash's Avatar
Bikertrash
For the price of tha FASS pump I could buy 3 OEM pumps.
