tire size on stock rim?
Old Mar 12, 2006 | 04:27 PM
heresdamanladies's Avatar
heresdamanladies
Default tire size on stock rim?
i just bought a 06 2500 cummins yesterday i was wanting mud terrains for it you can put 33's on but for a little more i can get a leveling kit and i can put 35 1250s on with the kit. my question is can i fit 35 1250's on a stock rim? thanks alot
Old Mar 12, 2006 | 09:44 PM
Glock Guru's Avatar
Glock Guru
Default RE: tire size on stock rim?
33" on a stock rim with a 2" front leveling kit is the max. If you want to go to a 35" tire you will need a lift kit. Also the stock rims would be at the minimum as far as the with goes.
-Troy
Old Mar 12, 2006 | 10:19 PM
mikahb's Avatar
mikahb
I'm running 35x12.50's on stock rims with a leveling kit - works fine. I was worried about the width of the tire on this narrow wheel, but it looks and works great.
Old Mar 13, 2006 | 03:58 AM
heresdamanladies
awesome thanks alot
Old Mar 13, 2006 | 06:44 PM
steved's Avatar
steved
I ran 315x70r17s on the stock aluminum rims on my 04.5 2500...only a very slight rub on the lower control arm.
I had no lift.
steved
Old Mar 15, 2006 | 07:32 PM
bigmike's Avatar
bigmike
35's will fit with a 2" leveling kit, but if you have the wheel turned hard and bottom out, you will hit. 33/12.50 is as big as you can go and have no potential to hit or rub anything. that is getting a little iffy with 17x7.5 rims, but it should be OK
bigmike's Avatar
bigmike
Old Mar 16, 2006 | 07:57 AM
heresdamanladies
cool thanks alot
Old Mar 16, 2006 | 11:50 AM
steved's Avatar
steved
ORIGINAL: bigmike
Factory aluminum 17s are almost 9" wide...they fit the 12.50" wide tires fine.
steved
Old Mar 17, 2006 | 09:44 PM
mcohen's Avatar
mcohen
You can fit 35x12.5x17 on the stock dodge rim and to be honest, the only rubbing I had was on the control arms without the leveling kit. I'm running BFG M/T in that size and didn't have the leveling kit on for about a week prior to getting it . . . . I have to admit though, the leveling kit makes the truck look A LOT nicer. Don't forget, if you get the leveling kit, you need new shocks (there's not enough room left in the stock ones).
