third brake light
Old Mar 23, 2006 | 07:37 PM
CATMAN's Avatar
CATMAN
Default third brake light
I installed a prodigy brake controller with the factory dodge pigtale. After I hooked it up the trailer brakes didn't work I noticed that the third brake light wasn't working when you use the brake pedal but it works when you use the lever on the controller. The trailer brakes do not work either way. I unplugged the controller completly and the third brake light still does not work. Please tell me you have some ideas.
Old Mar 23, 2006 | 07:52 PM
Ram_Sport's Avatar
Ram_Sport
Default RE: third brake light
could bulb be burnt or fuse blown?
Old Mar 23, 2006 | 08:51 PM
jw_hendry's Avatar
jw_hendry
I had a bad experience with brake controllers too. On a Dodge and on a Chevy. I was taking the factory pigtales and just matching the colors to the controller. Bad idea... It has been a while, but I think blue was the only wire that connected straight to the blue on the controller, the others did not match up. I had to use a power tester and the diagram on the controller to solve that puzzle. Burned up a few controllers before figuring it out. Don't know if this is the same kind of trouble your having, but good luck.
