silencer ring
Old Mar 26, 2006 | 09:51 AM
zach_deerefan's Avatar
zach_deerefan
Default silencer ring
what is the piece of plactic between the two elbows on the stock air intake beforee the turbo? is this baffle also called the siclencer ring?
Old Mar 26, 2006 | 01:40 PM
06LiftedRam's Avatar
06LiftedRam
Default RE: silencer ring
The piece you are refering to is not called the silencer ring. I am certain it is a well thought out invention to help cut down on turbo noise. How much??? I can't say.
Old Mar 27, 2006 | 12:16 AM
zach_deerefan
thanks took it out and sounds the same.
Old Mar 27, 2006 | 10:12 AM
Drew's Avatar
Drew
that is the intake baffel, you wont hear your turbo untill you get that out. you can take it out by dremeling off the end of the tube on both sides, but still leaving enough to get the rubber boots back on. once you have both end cut off take a hammer and knock it out.
replace it all and you'll hear a jet underneath the hood
Old Mar 27, 2006 | 01:29 PM
brampage's Avatar
brampage
also in the tubing leading to the turbo is pieces to make it quieter..... take off the bending ends and then I think its easy to take out...... you might have to get a whole new hose though
Old Mar 30, 2006 | 03:43 PM
steved's Avatar
steved
There are also directional vanes in the lower elbow at the turbo...mine was half cocked in the tube and partially blocking the inlet...
I took it out.
steved
Old Mar 31, 2006 | 12:13 AM
Flent's Avatar
Flent
Well I removed mine and from start to finish with removing the baffleing inside the black tube it only took me 20 mins. The silencer ring poped out in like 2 seconds. I did not cut the ends of the baffle tube, I just took a hammer and screw driver and knocked out the baffleing. Punch it right down the middle of the X.
ALSO MAKE SURE YOU GET ANY LEFTOVER PLASTIC OUT OF THAT THING. you do not want your turbo to find it...
I left the directional veins in the bottom elbow by the inlet on mine. I was afraid to remove it and have the hose colapse. I know the chances of that are slim but that is how my luck is
As for the improved sound.. WOW I can now hear my turbo at lower rpm's and at 75mph she is screaming. Then when you punch it at 75 it goes into this pitch that would make a dog howl.
I give this 2 thumbs up..
Old Mar 31, 2006 | 11:23 AM
steved's Avatar
steved
ORIGINAL: Flent
I doubt it would collapse...been running without one for well over 1.5 years...was your's sitting in the elbow correctly when you had it apart?? Mine had gotten wedged out of position and was blocking about 1/2 the diameter of the pipe.
steved
Old Apr 5, 2006 | 03:47 AM
jw_hendry's Avatar
jw_hendry
I just removed the baffles on my intake. Flint was right, all I did to take that black X out was punch it with a hammer and screw driver right down the middle.
As for that dirrectional baffle in the bottom elbow, mine was in there nice and straight. No problem pulling that out.
I'm on my was out right now to tackle that little silencer ring. I just put a new air filter in today, so tomorrow she should really sing.
