Re-Ratio TheRear -end
Old Apr 3, 2006 | 05:20 PM
BFR's Avatar
BFR
Default RE: Re-Ratio TheRear -end
i have a 1998.5 with the auto and 4.10 gears. i just wish the overdrive was a little taller at 70 it turns 2200 which isnt to bad but i would like it to be a little closer to 18-1900
Old May 17, 2006 | 06:29 PM
cj5nutz's Avatar
cj5nutz
Junior Member
ORIGINAL: Drew
I have the same problem and I find myself popping out of 6th to find 7th some times[:@]
I have 4.10's and the NV5600. so at 2000rpm I'm only doing 62mph. but I love the 4.10's, it realy gives my truck major low end grunt. the only thing I have found so far that will let you keep the low end grunt and lower the engine RPM's would be either a U.S. Gear or gear vendors overdrive.
Drew I have the 6 speed also and seem to have the same thought , I am forever shifting out of 6 th into nothing , then back to 6 th... I am turning 1900 rpms at 60 mph.. does that mean that I have the 4.10 gear ratio?
Old May 18, 2006 | 01:11 PM
Deleted User's Avatar
Deleted User
Default [Deleted]
[Deleted by Admins]
Old May 20, 2006 | 05:26 PM
Drew's Avatar
Drew
tobinj is right, the g-56 equiped trucks only have the 3.73. why you are turning so many RPM's like me is that the final drive ratio is higher than the NV5600.
