MMO?
Old May 18, 2006 | 09:41 PM
Storm Chaser's Avatar
Storm Chaser
Default MMO?
I use PS every couple of tanks but what is the MMO everyone is talking about. Had a mech. tell me to use a qt. of autotrans fluid everytank but after reading these post don't think I'll take his advise. Plan on using PS every tank also. Ain't good at math so how much do you add to a 35 gal. tank?
Old May 18, 2006 | 11:59 PM
Blue600's Avatar
Blue600
Default RE: MMO?
MMO is Marvel Mystery Oil. Some are mixing it with PS.
Old May 19, 2006 | 02:26 AM
2000cummins's Avatar
2000cummins
Default RE: MMO?
I get a solid 3 miles to the gallon better useing Drews mix of 8oz MMO and 16oz PS every time i fill up. The two pay for themself at the pump.
Old May 20, 2006 | 05:09 PM
Drew's Avatar
Drew
Default RE: MMO?
dont use auto trans fluid. it is acidic and will eat the pump and injectors up.
16oz PS and 8 oz MMO is all you need to keep the injector pump, injectors, and engine happy, and with the new ULSD that will be showing up soon, your VP44 pump will need all the lubrication you can give it
Old May 23, 2006 | 01:03 AM
RedRacer44's Avatar
RedRacer44
Default RE: MMO?
I also got a solid 2.4 MPG better using the PSD/MMO mix on my last tank, I was happily surprised!
Old May 23, 2006 | 03:41 PM
jrlaidle's Avatar
jrlaidle
Default RE: MMO?
OK, so what is PS and PSD? Newbie to CTD, and all diesel for that matter.
Thanks
Old May 23, 2006 | 04:29 PM
Batphreak's Avatar
Batphreak
Default RE: MMO?
PS=PSD=Power Service Diesel
Checkout the Diesel Kleen +Cetane boost under products.
Old May 23, 2006 | 05:07 PM
Drew's Avatar
Drew
Default RE: MMO?
ORIGINAL: jrlaidle
Thanks
just stick around, you will be enlightened
Old May 23, 2006 | 10:01 PM
cj7 bob's Avatar
cj7 bob
Default RE: MMO?
Some say use the gray bottle, some say use the white bottle. What is the difference and which on works the best?
Old May 23, 2006 | 10:49 PM
RedRacer44's Avatar
RedRacer44
Default RE: MMO?
I've always used the white bottle and had good results.....always keep a bottle in the tool-box just for a lil' peace of mind
