Tire pressure
Old May 20, 2006 | 12:09 AM
derrelw's Avatar
derrelw
Default Tire pressure
Hey what are you running for pressure on what size tire/wheel ?
The factory sticker says that I should run 65lbs in front and 80lbs in the rear.
I'm going to try 50lbs front and 40lbs rear in an empty truck.
Seems like it rides a lot better and passes the "chalk test"
Factory 16"x6 1/2" wheels and 285/75/16 BFG AT's
Old May 20, 2006 | 02:28 PM
DBLR's Avatar
DBLR
Default RE: Tire pressure
In my 06 2500 the door lable suggest for my 265-70-17 load E, 60 lbs front 70 lbs rear. I would check to see what Dodges said to run in your tires, that is if that are of the same size that came on the truck new. Why not talk to your dealer whom you bought them from and or do business with.
Charles
