'05 recall for park lock done can it be undone
Old Sep 21, 2006 | 11:31 AM
CowboyBob's Avatar
CowboyBob
Default RE: '05 recall for park lock done can it be undone
You can put a second relay on the horn circuit so the horn will not blow, unless the actuall horn switch on the steering column is pushed in. You can even keep from losing the power lock honk, panic button honk and alarm by making the relay close the circuit if the engine is not running.
Old Sep 21, 2006 | 11:46 AM
CowboyBob's Avatar
CowboyBob
After thinking about this for a few more minutes, it would be easier to put the relay on the door switch so that if the door is open, the horn will not honk at all.
