bypass filter?
Old May 28, 2006 | 06:02 PM
derrelw's Avatar
derrelw
Default bypass filter?
Hey guys I'm interested in getting some real world info about bypass filters.
Anybody using one? Did you install it yourself?
What brand are you using?
Are the results as advertised?
Old May 28, 2006 | 07:59 PM
Drew's Avatar
Drew
Default RE: bypass filter?
I dont have one, but I hear many good things about the AMSoil one.
it filters 1 gallon of oil in about 20 min, and extends the life of the oil and main filter since the one you use is probably a 5 micron, the filters used in the AMSoil bypass filter particles down to 2 micron.
then you have the Franz toilet paper filter that can also filter down to 2 micron as well. I am unsure as to it's gph filtering capabilities, but there are as many people useing the franz as I know that use the AMSoil.
Old May 28, 2006 | 09:49 PM
steve05ram360's Avatar
steve05ram360
I read somewhere recently that the CTD motor leaves alot of soot i the oil? is it necessary to filter that out as well? I assume that is why the oil is black so soon after an oil change... would the buypass filter catch this?
Old May 28, 2006 | 10:51 PM
Drew's Avatar
Drew
I am unsure if the bypass filter would catch the soot, I believe it would but I dont know. and yes, soot is the reason why the oil turns as black as it does so quick.
Old Jun 3, 2006 | 08:52 PM
gametrail's Avatar
gametrail
HI!! GUYS and GALS I talked to the Amsoil people, and they told me it would get almost all the soot out. As soon as i can i am going to get one, then i will let everyone know how it works.
Old Jun 3, 2006 | 09:11 PM
gametrail's Avatar
gametrail
Here is the E-mail i got.
Thank you for contacting AMSOIL with your concerns.
In response to your inquiry, filtering out soot is one of the primary purposes of our by-pass system. While it cannot filter out all of the soot, it will greatly reduce soot levels compared to a standard full-flow filter.
Thank you again for the opportunity to respond to your concerns. As always, please feel free to contact us again if we can be of further assistance.
Sincerely,
Ed Kellerman
AMSOIL Technical Services
Old Jun 4, 2006 | 03:22 AM
bekim's Avatar
bekim
I installed the oilguard bypass system. It has a 2 micron rating and was a simple install. The cannister is mounted on the tranny support where the rear drive shaft comes out. It takes oil from the capped test port by the oil filter, and returns it to the oil filler cap with a billet replacement unit supllied with the kit. From what the manufacturer claims, the particles doing the most to wear out parts in the motor are 4-7 microns in size. Soot ,by the way is sub-micron size (that is less than 1 micron), hence not much soot is filtered out.
Most oil additives like boron and molybdenum, and TBN are sub-micron size and filtering them out wouldn't be good!
The Amsoil system as well as the FS2500 (fs2500.com) seem to be good systems as well.
I sent off a sample that has 5000 miles on the oil with bypass system installed last week. I'll be comparing it to the sample run for 5000 miles without the bypass system. I'll be sure and post the results as a testimonial to whether the bypass system is really doing something substantial, or just costing money for more specialized filters and hassle.
Cheers
Mike
