"95 Cummins won't start hot
Old Jun 15, 2006 | 01:05 PM
1978skin's Avatar
1978skin
Default "95 Cummins won't start hot
My 95 2500 4x4 will occasionally not start after it has been running perfectly. It will start for a few seconds and then just die. If I let it cool down completely, it runs fine. Is the fuel overheating? I'm afraid to drive it anywhere for fear of being stuck. Any ideas?
Old Jun 15, 2006 | 01:41 PM
steve05ram360's Avatar
steve05ram360
Default RE: "95 Cummins won't start hot
Welcome to DF, I moved your post over to the diesel forum for more exposure.
my 1st thought is your fuel pump/lift pump is failing, i'm no expert on the older (or newer) CTD's so i'm sure someone here will add in shortly...
Old Jun 15, 2006 | 03:47 PM
Drew's Avatar
Drew
these trucks have a mechanical bellows type fuel pump located down on the engine drivers side. it was not untill the VP44 that you have the lift pump.
I would say that would be my first place to look. then I would check fuel lines and possably replace them.
Old Jun 16, 2006 | 03:14 PM
1978skin's Avatar
1978skin
Is it an easyish shade tree fix or will I have to refer it to a mechanic? Any opinions?
Old Jun 20, 2006 | 11:25 AM
Drew's Avatar
Drew
shouldnt be too bad. I would say about three bolts and the fuel lines and your done.
just make sure you install it right when putting it back in
