Check Engine Help
Drew or someone:
I have a 06 CTD 2500 4X4 with only a Volant and Silencer Ring Removed engine Mods. Today I was pulling out onto the road after dropping of my trailer (~5000lbs loaded) off and gave it about 1/2 to 3/4 trottle and then the whole truck shut down and the check engine light came on. I pulled over and took the battery connections off to try to re-set the ECU and the light remained on....even after starting the engine; which to me, typically means a electrical problem....right?.......Does anyone have any clue?.....I am planning on taking it in tomarrow, without a appointment. and this place is a mad house; one of those mass inventory turnover places. Therefore, maybe I can fix it without wasting my entire day there.
Thanks in Advance!
Thanks in Advance!
turn your ignition to run three times and where the odometer reads out it will show you a P code. I'm guessing P0236 which is the MAP sensor over boost.
the light will go away after 5 starts if nothing is wrong.
besides, I was a dumb@55 yesterday, pulled off my air filter to do a little work and forgot to plug the AIT back in. now I have to stare at that light now[:@]
I need a code reader / code deleter.
