99 5 speed Cummins- hard to get into gear?
Old Jun 28, 2006 | 05:30 PM
darylkey's Avatar
darylkey
Default 99 5 speed Cummins- hard to get into gear?
It seems that the clutch isn't releasing all the way. Even at idle, sitting still, it's hard to get into any gear. Reverse seems to be the worst. Any suggestions?. I have pulled the floor mat thinking it sould be hindering it but that was no help. These things are slave cylinder released, correct? Any adjustment?
Thanks in advance.
Old Jun 28, 2006 | 06:41 PM
Drew's Avatar
Drew
Default RE: 99 5 speed Cummins- hard to get into gear?
sounds like you have some air trapped in the system need to bleed it.
Old Jun 29, 2006 | 02:13 AM
zach_deerefan's Avatar
zach_deerefan
can you bleed those things? our 97 did the same thing last fall and sometimes wouldn't release at all, kinda scary. and then all the sudden, it was fine, now this summer it seems to be acting up again?
Old Jun 29, 2006 | 10:43 AM
Drew's Avatar
Drew
you can bleed it just like brakes, make sure you have plenty of fluid on hand to fill the resivoir. bleed it at the slave cylinder.
Old Jun 30, 2006 | 01:38 PM
steve05ram360's Avatar
steve05ram360
and once you have it fixed, swap out the fluid for some redline fluid, it'll help shifting alot.
my '97 dak had problems going into 2nd sometimes if the syncros werent at the same speeds, put in the redline fluids in the tranny & in the rear end and shifting was pretty damn close to new. plus the rear didnt whine as much...
