Which tranny???
Which tranny???
Hi all. I'm going to be putting a CTD into a project vehicle in the near future. I'm wonder what various transmissions come on these trucks and the strengths and weakness' of each. I read on here that the pre '98 engines and the post '02 engines are the good ones. Which transmissions are compatible with those? At this point I think I want an automatic but I'm not totally against a manual. I want an all around performer, not all race or all towing. This will be a daily driver. Thanks in advance.
RE: Which tranny???
Pre '98s used the 47RH and the 47RE. It depends on what year your motor/electronics are as to what transmission you can use. The 47RH was used in 94 and 95 and is a better transmission in my opinion. It's hydraulically controlled, and the only electronics are 2 solenoids (1 for OD, 1 for lock-up) and some sensors. The 47RE is electronically controlled and is run quite a bit by the engine computer [:'(]
I believe the 03+ trucks used the 48RE automatic. I can't tell you anything about that transmission.
Likewise I can't tell you anything about the manual transmissions. Never been able to drive a stick without snubbin it out [8D] so I've never taken much interest in them.
RE: Which tranny???
the 48re tranny is just like the 47RE except a few differences in the clutch pack to enable it to handle the higher torque numbers comeing off the engine.
the manuals that have been used on these engines from dodge have been the NV4500HD(5spd), NV5600(6spd), and the new G-56[:'(]
your best bet would be to contact ATS and see what they have to say. they can get you a tranny that is streetable, but is also unbreakable
