P 0071
Old Jul 8, 2006 | 06:44 PM
mdeps's Avatar
mdeps
Default P 0071
This code came up on my 06 Mega Cab, for the second time. Dealer didnt do paper work on it the !st time, just cleared it and sent me on my way. They will this time. Anyone no what it is? And thanks for the info. on how to get the cel codes, very useful.
Old Jul 9, 2006 | 02:11 AM
BlkRam69's Avatar
BlkRam69
Default RE: P 0071
The only thing I came up with searching for P0071 on Dodge / Chrysler was "ambient temp sensor performance" and / or "batt. temp. sensor perf" Cant tell ya more than that though.
I did find a PDF of a list of codes from a Dodge / Chrysler SuperChips DTC reader.
Heres the link. (hopefully)
http://redhat3.admarkonline.com/~sup...install-34.pdf
This is pretty fine print so youll have to use the zoom or magnify icon on the tool bar.
Hope this helps.
Old Jul 11, 2006 | 10:24 AM
Drew's Avatar
Drew
Default RE: P 0071
if you look in the FAQ section at the top I posted a link to a site that has a good breakdown for the trouble codes. . .only thing is '00' arent in it. it starts at '01' and anything above 1000 is manufacturer specific.
most of the codes I see are in this list and generaly narrow down to either the MAP sensor voltage too high or low, or the IAT.
Old Jul 11, 2006 | 12:28 PM
dodgedlr's Avatar
dodgedlr
Default RE: P 0071
When I do an LOF on diesels I take the inlet hose off the turbo and unplug the MAP sensor then remove the housing.
If I forget to plug the sensor back in, that is the code I get.
Not that I expect that to help you, I just wanted to share.
Old Dec 24, 2007 | 04:56 PM
nickcoletti's Avatar
nickcoletti
Default RE: P 0071
i just got this code on my truck today, i tried to understand the break down of it but its still latin to me.... anyone know if its a serious problom or somthing to just put off untill its conveinent to get to?
Old Dec 25, 2007 | 12:19 AM
Parts/Service's Avatar
Parts/Service
Default RE: P 0071
There is a TSB that deals with this. It involves "flashing" new software. I just did this flash on a members truck and it took care of his problem. Hope this helps.... Let me know if you have any questions... Click and read >>>>>> http://dodgeram.info/tsb/2006/18-005-06a.htm
Old Feb 26, 2019 | 05:27 PM
Dave Vachon's Avatar
Dave Vachon
Default It's the ambient air temperature sensor.
It's located on the drivers side behind the grill. Should see it next to the radiator just to the right as you're facing the the engine. 14.97 with shipping from Rockauto.com
