98 cummins 24v wont start when warm
Old Jul 13, 2006 | 03:19 PM
cutlerone's Avatar
cutlerone
Default 98 cummins 24v wont start when warm
I just bought a 98 1/2 3500 with a 5.9 cummins and a 5 speed standard (150,000 mi). The truck starts fine cold, and runs great, shut it off after running it for 30 min, wait 5 min and it starts fine, wait 10 min and it still starts fine, but wait 30 min and it wont start without ether. Another point is under heavy hauling I am losing oil out thr breather tube. help! The local dealer says these engines should be rebuilt every 100 thousand miles. I find that hard to believe.
Old Jul 13, 2006 | 03:26 PM
RustProofCorn's Avatar
RustProofCorn
Default RE: 98 cummins 24v wont start when warm
That guy is smoking the gunja...
Old Jul 13, 2006 | 04:02 PM
Drew's Avatar
Drew
ORIGINAL: RustProofCorn
I'll second that
anyway, your lift pump is probably looseing prime, need to change it out before you kill the VP44 injector pump which is expensive.
second, I would pull the valve cover off and re-lash the valves, then I would pull the radiator off and have the thing rodded out to remove corrosion. sounds like the engine is getting a bit warm.
