Lug Nut torque??
Old Jul 26, 2006 | 02:29 AM
dhbgl1800's Avatar
dhbgl1800
Default Lug Nut torque??
anyone know the recommended torque for the lugnuts with polished alum. wheels, CTD 2500 4x4?
[IMG]local://upfiles/23361/51F48AEB00114EB89B73ECAD786E5474.jpg[/IMG]
Old Jul 26, 2006 | 03:14 AM
RAPOM's Avatar
RAPOM
Default RE: Lug Nut torque??
I want to say 118ft lbs but I'm not sure. I would say call the dealer but they use impacts and probably don't even check the torque. A tire dealer would also know. The best one I've heard was "tighten it til its about to snap then back it off some". SEMPER FI
Old Jul 26, 2006 | 10:56 AM
Drew's Avatar
Drew
your lug nuts take more torque than a ricers engine can produce. . .clear as mud
BTW, 100 pounds is about right for all wheels but it would be good to call the dealer to make sure.
Old Jul 26, 2006 | 02:13 PM
ramtradxb's Avatar
ramtradxb
I torque mine to 100 ft. lbs, as that is what the wheel shop I bought them from said they should be. Had 60K on '04 CTD with alum 20's, and with those torqued to 100 ft. lbs. I never had a problem...
Old Jul 27, 2006 | 01:39 AM
dmdzlpwr's Avatar
dmdzlpwr
I torque mine to 135 ft. lbs. I have the 2 service manuals. Under torque specs it shows 130-135 ft. lbs.
Old Jul 27, 2006 | 02:53 AM
bekim's Avatar
bekim
2004 and before 1500/2500 models 135 ft/lbs
3500 145 ft/lbs
2005 up
1500 95 ft/lbs
2500 145 ft/lbs
3500 155 ft/lbs
according to Haynes
Cheers
Mike
Old Jul 27, 2006 | 11:50 PM
jakebrake's Avatar
jakebrake
go till they strip then back off 1/4 turn
