newbie just bought 06 cummins!!
Old Aug 1, 2006 | 06:00 AM
i11m10c2's Avatar
i11m10c2
Default newbie just bought 06 cummins!!
i just traded my mega cab 4x4 hemi for a new 06 cummins 3500 4x4 ,im coming from hemi side of the fourum i hope to find the same kind of great people and advice here will post pics tomorrow and update my info
i never thought i could get a diesel but with 10 mpg on the hemi and EP pricing it worked out
so i will be putting forth the usual stupid newbie questions for the next month or so so please bare with
Old Aug 1, 2006 | 12:22 PM
Drew's Avatar
Drew
Default RE: newbie just bought 06 cummins!!
not a problem. . .BTW, fuel mileage at first will suck, but get some miles on her and it will improve
Old Aug 1, 2006 | 06:54 PM
i11m10c2's Avatar
i11m10c2
ok first questions
(1 silencer ring what is it?
(2 cat converter is that the realy expensive looking thing behind the turbo(it is huge)
(3 break in ?
and it is maybe just me but the truck is a little to quiet for me anything i can do to louden it up a bit?
Old Aug 1, 2006 | 07:06 PM
Drew's Avatar
Drew
#1. take the intake tubeing off from the filter houseing to the turbo, first you will need two flat head screwdrivers, one to wiggle under the snap ring holding the silencer ring in and the other to hold it back while your working it out. once you have the snap ring out the silencer ring will just fall out. Then in the hardened section of the intake you will see a X baffeling, dremmel off ONLY the raised ends and take a rubber mallot and knock it out then re-install everything, your turbo will now sound like a 737 taking off. or if you follow the route I took and installed a NAPA 2790 air filter in place of the stock air box you will then have a 777 under the hood
#2, yes that is a cat and depending on your area you can remove it. if in california you will need to leave it in, my area there are no inspections or anything on diesels.
#3, for the first 500 miles be easy, this is the time where the axels and tranny is seating itself. after that drive it like you stole it. after about 20K the engine will be pretty much worn in, but still not broken in. after 20K if you want to make the switch to synthetics that would be the time. but before 20K stick to dyno.
from the factory the axels, tranny, and transfer are filled with synthetics, and the engine has dyno juice in it.
now, if you want to make her loud, remove the intake baffeling and silencer ring, get a 5 inch turbo back exhaust that dumps into twin 6 inch stacks that come out of the bed. not only is it bad@55 looking, but it will be loud
Old Aug 2, 2006 | 02:57 AM
i11m10c2's Avatar
i11m10c2
ok took intake out, top hose, hard x tube center ,and bottom hose dont see any ring ? onbottom hose plastic air deflector thing white in coulor as for x pipe how do you dremmel the peice out ? any pics?
thanks
Old Aug 2, 2006 | 04:32 AM
i11m10c2's Avatar
i11m10c2
ok figured out ring is on turbo (yea im retarded) but how you get cross plastic out, dont see the high spots you are talking about??
Old Aug 2, 2006 | 01:46 PM
Drew's Avatar
Drew
where the rubber piece overlaps there is an edge for better sealing. that edge is actualy both pieces melted together, remove that edge off both sides and it will fall out. take a damp sponge, wipe it out and your good to go.
Old Aug 3, 2006 | 03:22 AM
i11m10c2's Avatar
i11m10c2
ok all done pretty easy,but not a real improvement in volume? there is also a white plastic thing in the rubber tube right before the turbo looks like air deflector /is this why no real turbo noise ,or is it that im still babying it slow take offs no revs above 2000?
Either way thanks for the awsome advice look foreward to bending your ear about lots of stuff
thanks SIMON
Old Aug 3, 2006 | 10:24 AM
Drew's Avatar
Drew
the white plastic thing just helps direct the air flow, I took mine out. you wont realy hear the turbo unless you stand on the throttle a little bit
Old Aug 4, 2006 | 01:21 AM
i11m10c2's Avatar
i11m10c2
I want to stand on it hard you have no idea,but have to restrain myself for 382 miles then i can have some fun.
