06 does it have lift pump and vp pump??
Old Aug 17, 2006 | 01:48 PM
i11m10c2's Avatar
i11m10c2
Default 06 does it have lift pump and vp pump??
does my 06 have a lift pump and the deadly vp 44 pump or did they fix it on the 06 model am realy worried about long term especialy if i add edge and other mods that seem to make problems with these come up sooner.
Old Aug 17, 2006 | 02:22 PM
Drew's Avatar
Drew
Default RE: 06 does it have lift pump and vp pump??
the VP44 pump was fazed out in 02. in 03 the HPCR engines useing the CP3 pump was introduced. the CP3 so far has been a good pump that wont fail when the lift pump does.
now about the lift pump. in 05.5 somewhere, the filter mounted lift pump was moved from there to in the tank. DC thought it would be a good move to do this in order to keep the pump cool. well, it still fails. it can be replaced, but now you have to drop the tank in order to replace the pump. I tend to think the pump was moved to the tank to make it more expensive and troublesome for people to add aftermarket pumps to increase performance, kind of a deterrance.
Old Aug 17, 2006 | 03:31 PM
dodgedlr's Avatar
dodgedlr
We have seen very few of the newer in-tank pumps fail.
In fact I can only think of one off the top of my head, that was on a late-build '03.
I don't know what theier logic was in doing this, but I think it seems to be working.
EDIT: come to think of it, that '03 was of course the original filter mounted pump - but it was replaced with an in-tank module.
So I guess we never have replaced one.
Old Aug 17, 2006 | 03:54 PM
Drew's Avatar
Drew
I have read of a few that have died, not many and they are few and far between.
when mine finaly kicks the bucket fass or walbro for me
Old Aug 17, 2006 | 04:29 PM
Gimpydog's Avatar
Gimpydog
I just purchased a new '05' so where do I find the lift pump if it isn't in the tank. Frame mounted or is it attached to the block.
Old Aug 17, 2006 | 05:03 PM
Drew's Avatar
Drew
it will be mounted on the back of the fuel filter close to the firewall if it is not in the tank.
if your build dat is sometime in Jan 05 then you might still have the last few that were mounted to the fuel filter. there were quite a few mechanical changes that happened from 05 to 05.5, lift pump, Manual tranny just to name two.
Old Aug 18, 2006 | 05:48 AM
i11m10c2's Avatar
i11m10c2
cool !! thats a relief ok now i wont worry as much
thanks for the replys
