Cummins blowby
Old Aug 29, 2006 | 03:43 AM
Arky127's Avatar
Arky127
Default Cummins blowby
1998 Dodge Cummins blows oil (not fumes) out of vent pipe. Head completely reworked and same problem. Idle or wide open does same thing. Any help?
Old Aug 31, 2006 | 11:48 AM
jcrich47's Avatar
jcrich47
Default RE: Cummins blowby
I had a 98 and had the same problem. I found out that there were some 98's that had the wrong oil dipstick installed and would allow you to over fill the crankcase by over a quart. There were even part numbers posted on some web sites and mine was of the wrong number. I started filling the crankcase with the correct volume and not what was shown on the dipstick and the majority of the oil blow by went away. Sorry, I have lost the web site info that discussed this problem.
Thanks
James
Old Aug 31, 2006 | 12:26 PM
Drew's Avatar
Drew
hmmm. . .that sounds like a good reason why your getting excessive blow by sicne the crank would have to be turning through the oil and churning it up.
I was gunna say it is normal, but I can see that as well.
