any word on the hard start flash?
Old Oct 10, 2006 | 02:49 PM
chadg2's Avatar
chadg2
Default any word on the hard start flash?
Just wondering if there is any word on the computer flash for us with manual trans. and over crank before starting problems? I want to get mine in to turn on the high idle and would like to do both at the same time. Thanks.
Old Oct 11, 2006 | 11:15 AM
Drew's Avatar
Drew
Default RE: any word on the hard start flash?
the high idle you will have to have a wire fabricated in order to use it, pin #22 on ECM plug B (the one to the rear). this works only on the 05 and earlier trucks, the 06's use a CAN bus that operates a bit different and I am not sure how to hot wire those right now.
the hard start flash is where the computer does not have to recieve a signal from the crank sensor right away. most of your timeing and starting comes from the CAM sensor, however the computer also has to see something from the crank sensor. the flash just removes that and the engine initialy only starts with CAM only input then picks up the crank.
