SINGLE WHEEL TO DUALLY CONVERSION
Old Mar 28, 2007 | 03:27 AM
RideIcon's Avatar
RideIcon
Default RE: SINGLE WHEEL TO DUALLY CONVERSION
I've heard of dually to single conversions done and would like to know if anyone knows any links or anything. or if anyone has a single rear wheel truck that would like to become dually?
i had a 01 cummins single rear wheel and i have a 02 powerstroke single wheel but im thinking of getting an 03 cummins dually and converting it to single rear wheel. now i know what your all going to say, just get the 2500... yeah but i want gvwr to be over 10,000
reason... i get to many tickets for having a massivly lifted truck and would like that california loophole of no restrictions on trucks with gross over 10,000lbs. thats my f250
Old Mar 28, 2007 | 03:29 AM
RideIcon's Avatar
RideIcon
and i hear if you rip the dually flairs off some bushwacker flares cover up the hole with a little triming..
Old Mar 28, 2007 | 09:12 AM
Watermelon's Avatar
Watermelon
Im pretty sure the front spindles are differant on a dually. To run the rear wheels up front you gotta change em. I know the spindle on mine is massive and its a dually. O by the way its a sealed bearing assembly [:@]
Old Mar 30, 2007 | 05:40 PM
BLEWMONEY's Avatar
BLEWMONEY
you might want to look int this a little further, the part number on the axle housing is different on a dually than single rear wheels. i just looked it up.
when we order rear axle housings they are different srw, and drw.
Old Mar 30, 2007 | 05:43 PM
BLEWMONEY's Avatar
BLEWMONEY
the front hub and bearing is what is different not the spindle.
Old Mar 30, 2007 | 06:24 PM
Watermelon's Avatar
Watermelon
My Bad
Old Mar 30, 2007 | 09:41 PM
Captain Squalus's Avatar
Captain Squalus
ORIGINAL: i11m10c2
Has anyone converted from single wheel to dually? dosent seem to hard .New fenders ,lights ,wheel hub adapters,and wheels ,from the build sheet on my truck everything on my truck is the same as a dually except the afore mentioned equipment.??
The rear axle housing is wider on a dualy.
This is to put the center of the load in the center of the wheel bearings.
If you use a hub addaptor the load will all be carried on the outer wheel bearing and the inner wheel bearing will have a negative load.
see attachment
Net result is that you will be able to carry less wieght with the dwr conversion with an addaptor than you can with a swr.
ps the front hubs are diiferent also.
[IMG]local://upfiles/56817/7356E22EC9BC45CBBD2171CD66080108.jpg[/IMG]
Old Aug 9, 2007 | 09:01 AM
BLEWMONEY's Avatar
BLEWMONEY
u might want to look into the axle housing info a little more the axle code for single rear wheels is DRQ and dual rw is DRX the ratio being the
same the part number for the housing is different. i looked into this once and gave up. we traided my truck last year to get drw.
the axle housing part numbers were 5093001AA if it was DRW and 5086920AA if SRW and that is an empty housing with no internal parts, no brakes etc. i dont know what makes the housing different, it doesnt seem that it should be.
Old Aug 9, 2007 | 11:35 AM
NCcummins's Avatar
NCcummins
i think it would b sweet....do it!
Old Aug 9, 2007 | 01:30 PM
CowboyBob's Avatar
CowboyBob
Don't forget beefing up the suspension and brakes if you want a true 3500.
