fuel injector problem
RE: fuel injector problem
sincec you already have the warranty thrown out the bay door from the stealership you might as well look at something aftermarket. you'll find a mild HP increase with a mileage increase as well. KAX makes a 30hp injector set (I think) that runs less than stock injectors
oh and steve, the injectors only change the spray pattern for better atomization. the ports are honed slightly so they are a bit larger, but under stock conditions the rail will not run dry. toss a pressure/duration box and you'll need to hold on to your undies with the 100hp set.
Steve, why is it when ever I log in here and speak of something you're on the edge of your seat ready to buy it
heres the site Kax Motor Sports
I searched the site as best I could over the 24.6K connection I have at home and all I could find was 50hp injectors. I would imagine if you gave them a ran they could tell you all they had
