never run the rail dry again. . .
Old Oct 25, 2006 | 07:14 PM
Drew's Avatar
Drew
Default never run the rail dry again. . .
Dual CP3's anyone???
for 3,995.00 it can be yours. . .steve
Old Oct 25, 2006 | 07:28 PM
Mayfair's Avatar
Mayfair
Default RE: never run the rail dry again. . .
Not just one, but TWO CP's ???
WOW !!!!
Old Oct 25, 2006 | 07:45 PM
ga_noplugs's Avatar
ga_noplugs
Enough fuel for 1200HP?!!?!?! [sm=jawdrop.gif]
[IMG]local://upfiles/39935/E59B94C15F7E4853AE7138C0E9F6617F.jpg[/IMG]
Old Oct 25, 2006 | 11:00 PM
she torques me's Avatar
she torques me
Um...what am I looking at? Gonna need a little education here
Old Oct 26, 2006 | 01:03 AM
steve05ram360's Avatar
steve05ram360
ORIGINAL: Drew
hahaha... .no I think a $450 walbro kit should hold me over...
Old Oct 26, 2006 | 02:24 AM
speakle's Avatar
speakle
Ah what the hell, put me down for 2.
Old Oct 26, 2006 | 03:08 PM
cookie_monstr's Avatar
cookie_monstr
ORIGINAL: she torques me
dont worry ur not the only one. guys a little help here....wat are we looking at. i want to learn too
[sm=boohoo.gif]
Old Oct 26, 2006 | 03:44 PM
Drew's Avatar
Drew
ORIGINAL: cookie_monstr
[sm=boohoo.gif]
at the bottom left of the pic is the origional CP3 injector pump that came stock on the truck(but more chances than none it was replaced with a higher output unit). On the top of the engine you see a silver tube, that is the upper coolant hose, under that hose is another CP3 to supply even more fuel. the only downside I see of this design is it is belt driven and not gear driven.
some high HP guys are haveing to go this route since they have huge sticks with duration and pressure boxes causeing the fuel rail to run low on pressure. When this happens the engine looses power. All this setup is doing is doubling up on the fuel supply. the Isuzu Duramax engine uses the exact same injection system as our trucks, however the CP3 is a hair different allowing it to draw its own fuel from the tank. The Cummins has one rail with 6 ports, the Isuzu engine has two rails, one for each bank, from there they plumb a CP3 into each rail with a crossover tube to help equalize pressures to maintain engine performance if the pumps dont run the same pressure.
none of us here are anywhere close to needing a setup like this, the stock CP3 is more than capable of fueling to around 700+hp, I dont have the cash to make that much power[8D]
Old Oct 26, 2006 | 03:52 PM
she torques me
Thanks drew, top notch explanation. [sm=smiley20.gif]
Old Oct 26, 2006 | 03:58 PM
Drew's Avatar
Drew
also if you look at the fuel rail, the thing right above the fuel filter, you will see something that looks like a deep well socket turned inside out. that is the pop off valve. it realeases pressure on the rail if the pressure goes above 23-26,000 psi. once that thing pops just once it has to be replaced and costs around $220+ from the dealer. a good indication of that thing being bad is low power and the engine stumbling at rpm's above 2000.
this is why I dont care much for pressure boxes.
