shifting problem PLS HELP!!!!!!!!!!!!!!!!!!!
Old Nov 5, 2006 | 09:27 PM
2001dodge2500's Avatar
2001dodge2500
Default shifting problem PLS HELP!!!!!!!!!!!!!!!!!!!
I have a dodge ctd 2500 2001 the electronic torque converter looses signal intermitanly and the dealer can't seam to find why any suggestions!!! It does it when you have the truck under load ie. up hill ac on. I locks and unlocks repeatedly.
Old Nov 5, 2006 | 09:43 PM
NickBeek's Avatar
NickBeek
Default RE: shifting problem PLS HELP!!!!!!!!!!!!!!!!!!!
Has anyone checked all the wiring. Could be chaffed wire/s.
Old Nov 5, 2006 | 10:48 PM
2001dodge2500
they checked all wireing and cleaned all grounds
Old Nov 5, 2006 | 10:53 PM
DieselDemon's Avatar
DieselDemon
Have the dealership check the plunger position on the brake light switch. If it is out of adjustment, the tc will kick in and out. It will also be near impossible for the cruise control to keep speed. Notice if slight bumps kick the TC in and out.
It's a long shot but it was common back in the mid 90's on the Rams...
Good luck.
Old Nov 6, 2006 | 08:29 PM
2001dodge2500
i will have them check that thanks!
