TURBO
Old Nov 7, 2006 | 01:50 AM
brads05diesel's Avatar
brads05diesel
Default TURBO
I JUST TOOK THE SILENCER RING OUT AND I CHECKED THE SHAFT IN IT AND IT WAS JUST A LITTLE LOOSE!!
HOW LOOSE OR TIGHT SHOULD IT BE '05 34,000 MILES
Old Nov 7, 2006 | 02:17 AM
steve05ram360's Avatar
steve05ram360
Default RE: TURBO
you will get a little bit of movement, it's normal... too much however is not. I also had the same thought when I moved my impeller... talked with an expert, he showed me a new one which had basiclly the same play in it.
Old Nov 7, 2006 | 03:33 AM
SpLaT's Avatar
SpLaT
Default RE: TURBO
should have some front to back play... up and down play not good, but as steve05ram360 says a liitle is ok
Old Nov 7, 2006 | 11:34 AM
brads05diesel
Default RE: TURBO
THANKS GUYS JUST WANTED TO CHECK IT OUT
Old Nov 7, 2006 | 07:46 PM
jakebrake's Avatar
jakebrake
Default RE: TURBO
As long as the fins don't touch the housing you are good.
Old Nov 7, 2006 | 07:56 PM
Mayfair's Avatar
Mayfair
Default RE: TURBO
ORIGINAL: jakebrake
Yeah buddy, watch your fins ...
Old Nov 7, 2006 | 07:58 PM
jakebrake's Avatar
jakebrake
Default RE: TURBO
Might have to go fishing now
